Author Topic: Anyone know a coaxial cable for 0-2GHz  (Read 1273 times)
Offline Cacao
  • Country: ph
« on: July 20, 2017, 12:05:13 am »
Can anyone help me find a coaxial cable that has a 0-2GHz frequency of operation and also has a BNC or SMA termination. Your help is much appreciated. Thank you.
Offline alm
Re: Anyone know a coaxial cable for 0-2GHz
« Reply #1 on: July 20, 2017, 12:10:54 am »
Voltage/power level? Length? Acceptable attenuation? VSWR? Mechanical requirements?
Any piece of wire will pass some signal at 2 GHz.
« Last Edit: July 20, 2017, 12:19:29 am by alm »
The following users thanked this post: Cacao
Offline tggzzz
« Reply #2 on: July 20, 2017, 01:37:20 am »
See this, then go here.
Gliding aphorism: "there is no substitute for span". Retort: "There is a substitute: skill+imagination. But you can buy span".
Offline daqq
  • Country: sk
    • My site
Offline bjcuizon
  • RF and Analog Electronics Enthusiast
« Reply #4 on: August 07, 2017, 04:28:28 pm »
You may find some here: http://www.mouser.ph/Wire-Cable/Cable-Assemblies/RF-Cable-Assemblies/_/N-bkrix?No=200&P=1z0x0emZ1yzsqvfZ1yzsqvg and here: http://ph.rs-online.com/web/c/cables-wires/coaxial-cable/coaxial-cable-assemblies/?searchTerm=bnc%20cable. It may be a bit hard to find a cheap price and the one that suits your needs. I know its really hard to find these things in the Philippines sometimes. (I can say that cause I'm a Filipino myself) The ones on our local stores just don't cut it. They usually just order it from a cheap supplier in China.
« Last Edit: August 07, 2017, 04:30:19 pm by bjcuizon »
Don't mess with an Electronics Engineer, it Megahertz!
Online ejeffrey
« Reply #5 on: August 08, 2017, 02:43:24 pm »
Almost any coaxial cable will work to 2 GHz for some values of "work".  Ordinary Rg-174  and RG-58 cables are normally specified as "up to 1 GHz." If all you care about is transmitting signals over a short distance (a few meters), they work fine at 2 GHz and even higher.  Their impedance, loss, leakage, and phase stability are not great at high frequency due to the braided shield construction, but they usually will get the job done.
It's hard to say if those limitations will be an issue without knowing your application.
