Author Topic: Can you make your own wifi router or dedicated data link for the internet?  (Read 8907 times)
Offline BeaminTopic starter
  • If you think my Boobs are big you should see my ba
Would it be possible to use your ham lic or ISM band etc, to set up a long range data link to access your internet from home?
Not super fast data links but take an internet connection and pipe it into something like a hackRF and connect up a directional antenna and then have another set up on a portable computer. Application would be having a cabin on your property and wanting it to get internet without using cellular data a mile or more away.
Max characters: 300; characters remaining: 191
Images in your signature must be no greater than 500x25 pixels
Offline TheUnnamedNewbie
  • mmwave RFIC/antenna designer
There are actually systems available for this. I know Ubiquity makes a lot of these systems for "long range" wifi. Either by using big parabolic dishes for 2.4, and I think they also have some systems that use a higher frequency to beam the data and then downconvert it back at the other end. I don't know about price, but remember some of them being suprisingly affordable (or at least I thought they were)
The best part about magic is when it stops being magic and becomes science instead
"There was no road, but the people walked on it, and the road came to be, and the people followed it, for the road took the path of least resistance"
Offline Bratster
Look at a Ubiquiti rocket M5 radio, rocket dish antennas.
There are some larger sizes and some smaller sizes as well depending on how long the distance is.
There are also a bunch more models. Some I think can even get you a 1 gigabit Link in both directions, or at least close to it.
We use the rocket m5 at work to get internet up to remote transmitter sites. 100 megabit link easy.
Sent from my Nexus 6 using Tapatalk
Offline David Hess
  • DavidH
You do not have your country marked but at least in the US, using an armature radio license for this is not feasible because of the content and even if it was, there are better solutions like the Ubiquiti radios that TheUnnamedNewbie mentioned which are exactly what you need to do this.
Configure a pair of Ubiquiti Litebeam radios to bridge (easy) or route (more difficult) between networks and you are good to go.
Offline ahbushnell
How long a range?  You can buy Wifi antennas that have hi gain.  that would be a simple approach.
Exactly !
You just need to power them POE and roughly point them at one another for 5km range.
https://www.streakwave.com/itemdesc.asp?ic=LocoM2-US
Then connect the remote unit to a WiFi access point or a remote switch.
Hey presto, long range home-group.  :)
Avid Rabid Hobbyist
Hak five explained how you do this legally. I guess the point of the video was that you would not detune the radio after setting it up like they did to get long range. The way they did it basically detuned the radio back down to what it was out of the box but I'm guessing you were supposed to read between the lines. Pinneapple or some inexpensive device. That show is so frustrating because they don't post the second half of the videos then you go to their site and can't find it because they took it down. Like having sex without getting off at the end. Why would you do that to yourself? Exercise?
Offline Lord of nothing
  • Country: at
SO where are you from?
To make it legally it realy depend where you life. For example here in Europe what I know the max. Output power on 433mhz Band is 0,5W and the duty circle is 10% when I remember right. The max Bandwith is 20khz I think?
Sure depend on your Country who not via CB Radio?
With Packet Radio you can Transmitt 24/7 legally.  :-DD
Made in Japan, destroyed in Sulz im Wienerwald.
In the US we have some some "junk" bands like the 27mhz/11 meter or 49 mhz thats dead since cordless phone abandoned them in the higher and higher ghz wars. Marketing thought right that people would think more MHz is better when in reallity the 900 mhz cordless phone is king. The CB band is abused so bad that you could use a few channels of continous 100 watt power and as long as you stay within the frequency minding your harmonics no one would care. Who would complain? Truckers using 100 watt over modulated radios complaining that they couldn't use racial and homophobic language at people? The CB band is just embarasing to listen to becase they tal in this weird accent and repeat words; it just sounds so stupid. In the 90's as a kid my friends all had one and we would make fun of the grown adults on CB. The  people were usually trailer trash and pedophiles I remember alot of guys used to try and get my phone number or want to meet in person. But now it's much worse. I lived on a hill had a 2 huge dipoles and would tweet the bias in the CB and modulation. Of course the CB would stop transmitting in a few months but at 40$ just buy a new one.
Offline KD4PBS
As others wrote, legally speaking, not likely.
Remember that as an amateur radio operator, you're restricted to a few rules that would not be easy to guarantee:
1) Can't run any kind of encryption.  So basically, all your everything that you do over this connection will not be able to be encrypted, including your login passwords, etc.  So, there'd be no using a SSL or an HTTPS:// web browsing session.
2) Can't use it for business at all. Even purchasing something on Amazon over this link (if you were able to log on without encryption) would be a touchy "gray" area.
3) Can't use it to browse anything that would be illegal to transmit over amateur radio, such as profanity, and that stuff that people say is the #1 reason people use the internets... pronography.
The following users thanked this post: Mr. Scram
  • Country: at
 ;D So CB or PMR446  >:D
Offline janoc
Technically this isn't a problem, however it could be iffy legally.
You certainly can do that but usually not on a HAM license. HAM licenses explicitly prohibit commercial traffic, so unless you are planning a HAM only network (such as HAMNet: http://www.broadband-hamnet.org/ ), you wouldn't be able to operate such setup for Internet access on a HAM license.
Doing it with ISM hw may or may not be possible - the ISM general licenses are usually tied to the hw including specifying allowed antennas and total EIRP which must not be exceeded. So doing something like adding a high gain antenna to your WiFi router (or something else) to extend the range may be very illegal. Check the applicable rules in your country before you engage in something like this otherwise you could end up with a really nasty fine.
However, what may well be an option is an optical link. Either using a laser or even high power LEDs + some lenses. A mile or two is perfectly doable and typically these things are not regulated/licensed (apart from laser safety regulations that may be applicable). The only problem is that you need a straight unobstructed visibility between the two points you want to connect - but that would very much be the case for the ISM band frequencies at such distance too. In the worst case a simple repeater (= mirror?) to bend the link around an obstruction could help too.
If you decide to go for this, there are commercial laser-based devices but you can also build it yourself - e.g. the Ronja:
http://ronja.twibright.com/ (10MBit 1400m airlink w/ LEDs ...)
« Last Edit: March 22, 2018, 10:22:15 pm by janoc »
yea but in reality no one is going to know or care. I don't think some one would go through the effort even if they could to prove some data sent over the air had the word fuck on a web page.
Offline KD4PBS
Sadly, that's the kind of thinking that many new amateur radio operators have.  Thankfully most of them think that 2 meters is the only band that exists, so they rarely cause any real problems for the majority of us who stay away from that band after getting sick of hearing people say things like, "How many bars am I puttin' on your meter?"  and "Well, my ess dubya arrs are better now that I cut a few inches out of mah co-axal."
Those buffoons find out very quickly what reality is when they start operating like this in an area where people do still care.  I guess there simply are lots of people out there who think that laws weren't made for them.  I, for one, enjoy watching their reaction when factual, truthful reality knocks their false reality in the mud.
Offline janoc
You are pretty badly mistaken here. People will call you out on HAM bands for much smaller transgressions than this. And some folks really do love sending complaints to FCC/whatever-your-local-authority-is-called.
It isn't about the word "fuck" or something else on a webpage but you will be breaking the restrictions on:
1) Carrying commercial (= public internet) traffic over HAM links - explicitly illegal for amateur radio service. This alone would get you busted and is trivial to prove.
2) Allowing unlicensed operators to operate HAM gear without supervision is not legal - depending on where you live, this rule is sometimes applied to a remote machine (router/server/whatever) connecting through your HAM link and thus "operating" your transmitter. This is often a grey area and very much depends on how hard the local regulator decides to throw the book at you.
E.g. in Slovenia they were using their high speed packet radio network to connect to the Internet but it wasn't legal to build something like that in Slovakia where I am from because of this rule, even back in the day when the Slovak internet was strictly non-commercial, academic network (so wouldn't break the point 1)
3) Encryption/scramblers/etc are not legal neither
So if you are planning on breaking the law, don't do it on HAM frequencies - unlike the other bands (ISM, CB, PMR  ...) where you are going to get caught only if you interfere with something that someone does care about or it is a government service (police, airports, etc.), on HAM frequencies many people are actually listening and you will get your backside busted sooner or later.
The fines are pretty juicy and even if you don't get fined, getting a surprise visit and having to show all your papers, logbook, have your gear inspected and measured with the government techs looking for the smallest problem to fine you on is not a fun experience. I know one HAM who had to go through this several times - because of an asshole neighbor not liking his antennas sending bogus complaints about interference to the regulator's office.
Not to mention that this is a pretty :wtf: attitude, especially if you have or are planing to get a HAM license.
« Last Edit: March 24, 2018, 05:07:29 pm by janoc »
Offline NiHaoMike
    • Facebook Page
Isn't the definition of "commercial" involve transfer of money or other item of value?
A workaround to the transmitter being controlled by an unlicensed entity is to not transmit until a licensed operator sends a "reply with data" command, so that the base station is acting as a transponder. Might also be possible to have it transmit based on a timer so it acts as a beacon.
Encryption is not allowed, but cryptographic signing might be. It does not obscure the content but does allow verification that it is an authentic message. It would not be very helpful for clandestine uses but would make it far more difficult for a hacker to impersonate a legitimate user.
Offline janoc
No. The exact definition is in the ITU documents but for the purpose of the debate it pretty much means "anything else but HAM traffic", i.e. communication with other licensed amateur radio operators. Heck, in most countries you are not even allowed to transmit messages on behalf of a third party, except if they are a HAM or in very limited set of circumstances such as emergencies or disasters.
The content of what is allowed to be transmitted is fairly strictly regulated, typically (quoting UK rules because they are in English):
Unless the Radio Equipment is being used for the purposes of clauses 1(2) or 1(3) in the UK:
(a)
Messages sent from the station shall only be addressed to other Amateurs or to the
stations of those Amateurs;
(b)
Messages sent from the station shall not be encr
ypted for the purposes of rendering
the Message unintelligible to other radio spectrum users.
(clauses 1(2) & 1(3) are about emergency comms)
That workaround doesn't work because the by the time the licensed operator replies your typical TCP connection would have timed out already. Also your regulator may not look at this kind of blatant attempt to skirt the rules lightly. But again, this may or may not be an issue, it depends on jurisdiction.
Another thing is that a HAM radio station must by default be manned by a licensed operator, in most countries you aren't allowed to setup automated stations (repeaters, packet radio nodes, APRS trackers on unmanned vehicles, whatever) without a special permit and obtaining a call sign for them. (There are exceptions - e.g. UK seems to allow this for personal use only but not for the use by other HAMs - that has to be licensed separately)
That completely misses the point. The issue with crypto is that you wouldn't be able to use any service that runs over an encrypted connection (https for ex ...) or to hide your personal data from anyone who is in range and has a receiver. Those are far bigger issues when transmitting data over radio than someone trying to inject a bogus packet.
If you want to see what how a typical version of rules covering HAM radio  looks like, here is the UK one:
https://www.ofcom.org.uk/__data/assets/pdf_file/0027/62991/amateur-terms.pdf
(UK for no particular reason except that it is in English and is a fairly typical EU-style reg.)
The US rules are here:
http://www.arrl.org/files/file/Regulatory/March%208,%202018.pdf
(US has a funky clause there prohibiting transmission of content that could be transmitted by other radio services - internet access would fall square under that. The idea is to not waste precious HAM bands on mundane things better served by other existing services already).
I suggest that anyone who thinks they have a "clever workaround" how to bend the rules and/or thinks it is OK to break them actually get familiar with them first.
HAM radio is really not meant to be used for things Beamin wants to do. That's straight in the domain of commercial hardware like microwave links operating either in the ISM bands or on dedicated (and licensed) frequencies.
73, Jan OM2ATC
« Last Edit: March 24, 2018, 10:08:01 pm by janoc »
The following users thanked this post: KD4PBS
My rule of thumb is if no one hears it your good. Use very directional antennas and cut down the power as low as you can.
But one time I did have the idea to give myself personal long range wifi when I lived on the roof of a building in the city. Go to your favorite restaurant and look you are on your home network!
You forget the risk of interfering with another's legitimate transmissions and that why we have dedicated bands for the many types of communication.
Go down this road of using another band NOT reserved for your intended use at your peril !
Avid Rabid Hobbyist
Offline Mr. Scram
  • Display aficionado
Considering how the internet is moving towards SSL, not having encryption isn’t possible. Even securing your connection with a password should be considered illegal. Not being allowed encryption means modern internet goes right out of the window. It’s not viable.
Offline NiHaoMike
    • Facebook Page
You can always run a browser on the base station and then do everything in cleartext over the radio - e.g. telnet into a Raspberry Pi running Lynx. You just lose the connection being private. And signing is not encryption - others can still read the information and they can use the public key to verify it really was you who sent it. I don't see why anyone would be against the idea of signing since a hacker impersonating legitimate users really doesn't do anyone else any favors. So while anyone would be able to see what you're doing, if you use a good signing algorithm, it would be basically impossible for a hacker to interfere with the connection in ways other than a DoS attack.
Offline ogden
  • Country: lv
Other option is Mikrotik LHG 5.
Obviously forget that you are HAM, use legal in your area ISM frequency.
Offline janoc
Nihao, sorry, but that's utter BS and you are making an exemplary strawman argument with the signing issue (which was never even a topic of discussion). Your "solutions" are both completely impractical (how would you control the browser?) and still completely illegal because regardless of the encryption issue, HAMs aren't allowed to transmit this kind of traffic. Please, do read the rules I have posted before you try to engage in some more "engineering exercise" trying to "solve" what is a legal and regulatory issue and not an engineering problem!
A lot of people who though they were being clever (and everyone else stupid!) wound up on the wrong side of the law because of this.
« Last Edit: March 25, 2018, 02:37:03 pm by janoc »
Offline janoc
You are forgetting that even directional antenna is not 100% directional, they emit in a cone which spreads out with a distance. Anyone within that cone can hear you.  And the signal doesn't stop propagating at the intended destination neither. So you may think no one is hearing you but you may be causing interference e.g. on the air band at the airport a mile or two downrange from your installation. Or a cell phone tower nearby, depending on the frequency and bandwidth/modulation type you decide to use/abuse.
Also no one hearing you doesn't mean nobody ever notices your antennas, for example. A microwave dish or a yagi have to be in the open to work.  And in that case it is a trivial matter to cross-check with the database of licensed operators (both HAM and non-HAM, in many countries these things are a matter of public record and include addresses of the people/companies holding the licenses) and see whether the installation is legit or not. And potentially call the inspectors.
So what you are describing are sensible things to reduce interference but they are absolutely no guarantee you wouldn't get caught.
If you really want to solve this problem (as opposed to just pointless trolling and stirring up "shit" in the forum), get either a commercial pair of radio modems or buy/build a laser link. Both are much simpler to deal with than trying to do it with HAM radio equipment which is not designed for this type of service. And both will also save you issues with breaking the law and getting fined/having equipment confiscated.
« Last Edit: March 25, 2018, 02:39:53 pm by janoc »
Offline NiHaoMike
    • Facebook Page
The signing is just a way to implement access control without encryption. You'll have a connection that's "secure" in the sense that it's difficult to spoof packets but not secure in that anyone can still read the data in cleartext.
Of course, it's starting to sound way more sensible to just use ISM and not have to deal with the amateur radio restrictions. Lora can do very long distances with very little power, maybe a modified version operating just within legal limits can be a good option?
