Author Topic: Cassegrain offset dish antenna : where is the beam ?  (Read 1399 times)
Offline jujunTopic starter
« on: September 29, 2018, 09:56:42 am »
Hello,
I just got for free a cassegrain offset dish antenna. So I am mounting it on my antenna rotator.
But I am facing a problem, it's not obvious at all to understand where the beam is in the vertical axis.
A picture of the different beam possibility, witch one is the good one ?
I must say that mechanicaly it would be easier if it was the blue or the yellow.
Also If you have any advice on this thing, I would love to hear them. (I'am thinking to add a focus motor)
Thank you
« Last Edit: September 29, 2018, 10:14:43 am by jujun »
Offline VK5RC
Re: Cassegrain offset dish antenna : where is the beam ?
« Reply #1 on: September 29, 2018, 10:23:43 am »
When I was mucking about with a 10GHz using an off centre fed dish (satellite dish) I used a weak signal source at about 30m away and found it experimentally - rather interestingly I also had a bit of a sideways squint as well !!! |O
The following users thanked this post: jujun
« Reply #2 on: October 05, 2018, 12:17:24 pm »
I will build a massive attenuator, and try. Thank you :)
