Push pull output, Class D low frequency (136kHz) RF amp, circa 500 Watts. If I want to test it for a few hours into a dummy load does it matter if the low pass filter network usually used to get a sine wave, harmonic free output into an antenna, is not between the output transformer and the dummy load? I want to leave it running overnight and I am modding the LPF and it's in bits until next week. Thanks.
