Hello,
Is there a good reference for which coaxial cable to use for a given power, frequency, and shielding desired?
I am looking at something to use with ~1kW at ~1.5MHz. Currently just a regular RG58 is used, which leaks RF noise everywhere into the lab, and gets quite warm. Visiting Pasternack's website, for example, I can a whole host of options that have >90dB of shielding and will handle the 1kW power, with prices varying over an order of magnitude, with no clear difference between options. Currently RG142 looks like a decent option, but maybe there is something else way cheaper that would work equally well.
Thanks!
