I finally made a 2 transistor regenerative receiver and it worked. I was looking at the output on the scope before I dug up a earphone and I thought it sure looked like audio being modulated and it sure was. I learned the basic saturation model for BJTs in the process and know some basics of AC loop analysis of oscillators.
I'm not into SMD scale , or software defined radio yet.
So for hobby level AM radio and up to say VHF (just listening btw, no plans to transmit anything),, Some things I have already, more or less for lower end RF stuff is
S9018 BJT
BF199 BJT
some VHF/UHF BJT
2n5485 Nch JFET
J112 "
J176 Pch JFET
LM7555 timer
1N34A Germanium diodes
1N60
only 2-3 variactor diodes
fast Schottky diodes
assorted 2 pin quartz crystals
few random ceramic oscillators and filters
pico/nano ceramic's
some NPO ceramic caps (had them for years, I just thought they old ugly '60s era caps)
30pF cermat trimmer caps
2-3 6pin variable cap
3 3pin vari-caps
1uH-4.7mH resistor style leaded inductors
assorted inductors from 1990-2010 TVs/radios/etc
hardly any canned tuned RF transformers, LC tanks, that I know work or are marked. I have a few I need to fix the wires back onto.
I do have some 4 pin inductor forms w/adj. cores I can make tiny tiny transformers on.
1cm green, yellow ferrite rings (ebay cheap so no idea what they are tho)
10cm ferrite rods.
26AWG and 36AGW magnetic wire
cable TV coax
Plenty to keep busy but it takes months for stuff to get here so I want it before I need it.
Some things I don't have is
OPAMPS for active filters above whatever LM358 can do, and RF in general
Litz wire, more wire gauges in general for coil making
more types of ring cores for toroid
more variable caps
variactors
practically no common or specialty ICs for anything RF like VCO, PPL (besides AM/FM radio ICs I hope to hack)
no copper clad boards
no V/A analog panel meters
Whats some more stuff I should have lying around ?
