I'm measuring a 1:8 power splitter and getting about 10dB of insertion loss at 2.4Ghz with my Anristu VNA. I'm measuring S21 with Port 1 on one of the input ports and Port 2 on the single output with all other ports terminated.
When I flip them, so port 1 is on the output and port 2 is on one of the 8 inputs, I get the same insertion loss.
I'm confused because I thought when used as a power combiner, there should only be the insertion loss of <2dB or so, but when you use it as a power divider, you have the full 9dB+/-<2dB.
Can someone explain what I'm doing or understanding incorrectly?
Thank you so much!!
