No, worse than that, assuming typical conditions (50 ohm source and load). Those ferrite plates likely offer ~100 ohms at 100MHz, or about 6dB, and not much more (mostly less) at any other frequencies. A 1nF cap rolls off at 6.3MHz (-3dB) and a feedthru worth its trouble should perform asymptotically above there (-20dB/dec).
But it depends. If there are caps either side of the ferrite bead, the local impedance can be quite low, giving acceptable filtering.
