I don't know how feasible it is, but from the block diagram it should be possible.... I just have no way of seeing inside the test set in question in advance, and wouldn't want to buy one only to find it was very challenging to modify.
The test set in question is the HP 87511B variant, half the price or less than the A variant because it's 75 ohm port impedance, and from the service manual, the difference seems to be a set of four minimum loss pads that are inside of the directional bridge assemblies. Basically I'm wondering if these minimum loss pads are going to be soldered in place or if they're just going to be inline with the rigid coax - because it would be a very easy modification to remove them and replace them with an appropriate adapter.
I've found the service manual here, and in the block diagram on page 44 is where I'm getting most of what I know about it:
https://doc.xdevs.com/doc/HP_Agilent_Keysight/HP%2087511A%2C%2087511B%20Operation%20%26%20Service.pdfIn this discussion of modifying a higher bandwidth test set (
http://k6jca.blogspot.com/2014/03/modifying-75-ohm-hp-85046b-s-parameter.html ), they didn't open the directional bridge, they just swapped them, and there is a difference between the two, at least in this variant. The service manual for that 85046A/B test set has electrical schematics that will probably match the board in the test set, since both the 85046 and the 87511 seem to be compatible with the same VNA (4395A, in my case).
So does it seem feasible that inside those directional bridges is an easily removable pair of minimum loss pads? Has anyone attempted this before or does anyone have pictures of the insides? I can just wait around to see if a 50 ohm version comes around at a better price, but getting my hands dirty and saving some money has its appeal.
