Author Topic: Discrete DC-few GHz FET device?  (Read 1460 times)
Offline toliTopic starter
  • Country: il
« on: January 14, 2018, 10:11:11 am »
Hi All,
I have a need for a device that has to withstand about 15V of VDS, and pass a couple 100's of mA's. The catch is it must be fast enough to operate up to a few GHz for the intended circuit.
I would prefer some sort of FET device for this application due to requirement from the circuit.
I normally design IC's, therefore, I have a very limited familiarity with discrete devices that go up to these frequencies. Short google search resulted in mostly bipolar devices, and all with very limited current handing capability (<10% of my needs).
Are there devices that would fit my needs?
Any general tips for choosing/using the device to meet the requirements?
Thanks.
My DIY blog (mostly electronics/stereo related):
http://tolisdiy.com/
  • Country: il
Re: Discrete DC-few GHz FET device?
« Reply #1 on: January 14, 2018, 10:38:43 am »
Thank you for the info  :-+
I will check this device and similar devices.
I'm actually trying to stretch it to above 6GHz. The circuit it works with works there, and I would like this additional device to have limited affect on the overall BW.
Online RoGeorge
« Reply #2 on: January 14, 2018, 10:44:14 am »
Is this for switching a 50 ohms termination?
  • Country: il
« Reply #3 on: January 14, 2018, 10:44:48 am »
It will be used as a linear device, not for switching.
