Author Topic: Discrete DC-few GHz FET device?  (Read 295 times)
Offline toli
  • Country: il
    • HWzone
« on: January 14, 2018, 09:11:11 pm »
Hi All,
I have a need for a device that has to withstand about 15V of VDS, and pass a couple 100's of mA's. The catch is it must be fast enough to operate up to a few GHz for the intended circuit.
I would prefer some sort of FET device for this application due to requirement from the circuit.
I normally design IC's, therefore, I have a very limited familiarity with discrete devices that go up to these frequencies. Short google search resulted in mostly bipolar devices, and all with very limited current handing capability (<10% of my needs).
Are there devices that would fit my needs?
Any general tips for choosing/using the device to meet the requirements?
Thanks.
Online blueskull
  • Country: cn
  • Power Electronics PhD Candidate
Re: Discrete DC-few GHz FET device?
« Reply #1 on: January 14, 2018, 09:36:02 pm »
You won't find a GaN MOSFET anywhere. Modern GaN devices are usually HEMTs.
This is a 6GHz GaN deplation mode HEMT: CGH40006P
If you are only interested in low-GHz (1.x GHz), then also consider to (ab)use EPC switching mode eGaN devices as linear RF amplifiers. You won't get performance of a real RF optimized GaN device, but you can get it for much cheaper.
SIGSEGV is inevitable if you try to talk more than you know. If I say gibberish, keep in mind that my license plate is SIGSEGV.
Offline toli
  • Country: il
    • HWzone
« Reply #2 on: January 14, 2018, 09:38:43 pm »
Thank you for the info  :-+
I will check this device and similar devices.
I'm actually trying to stretch it to above 6GHz. The circuit it works with works there, and I would like this additional device to have limited affect on the overall BW.
Offline RoGeorge
« Reply #3 on: January 14, 2018, 09:44:14 pm »
Is this for switching a 50 ohms termination?
Offline toli
  • Country: il
    • HWzone
« Reply #4 on: January 14, 2018, 09:44:48 pm »
It will be used as a linear device, not for switching.
