Howdy,
Being cheap and without a scope, I decided I would build a simple diode RF probe to check power output from one of my radios. I used a kit from
http://www.qrpkits.com/rfprobe.html. For a 5W CW signal into a 51.5 ohm dummy load on one of my DMMs (keysight U1252b) I get 12.6V out. I expect something in the 16V range. This does seem to vary with frequency, so that number was measured around 14 MHZ. Using an old Radioshack 22-802 DMM, I see the expected ~16V out.
Today I dragged both meters and the probe into work where we have more advanced diagnostic equipment (scopes, signal generators, etc). If I look at a sine wave @ 20 kHZ, 3V peak-peak I get 0.9821V out of several meters I tried (including the two above). That seems about right, and agrees with the scopes measurements for Vac RMS.
My question is, why am I not seeing this behavior carry over to the shack and my transceiver? I do notice that the output of the probe is not a level DC voltage, it's more of a sine wave which strikes me as a bit odd (see picture with blue trace below. Blue = probe output, Yellow = signal I'm measuring).
Two photos of the probe in use and corresponding readings are below.
