Hello ALL,
I would like to install a discone antenna for radio listening on HAM and free frequencies (433, 860) on the same pole of the DVB-T antenna (the only place I can install it)
Unfortunately It's very difficult to install another dedicated cable for it.
I'm not a RF guy, but I wonder - since it's only receving - if I must/can use some kind of mixer to mix the signal captured by the two antennas and keep using the existing 75R TV cable at the same time.
I guess in this case the discone should have a band stop filter for the TV signals to avoid signal canceling due to phase opposition of the signals.
I know that a shared cable is a potentially unwanted solution, but I've not other choices (indoor antenna or TV-shared antenna).
Thanks in advance for any suggestion/tip!
