Yeah, literally no one uses that toy of an equation.
Even Ebers-Moll is out, in the real world -- at least, for BJTs, you're likely to have encountered the Gummel-Poon model in a typical EE curriculum (if not work with it much, directly). Which is the more-or-less standard model used by SPICE.
AFAIK, practical MOSFET models are all much more complicated than this, and so you really only encounter them in SPICE: numerically, not symbolically.
Some detail here:
http://nitkkr.ac.in/docs/MOSFET_LEVELs.pdfLEVEL 1-3 models use KP, for varying reasons, mostly with a lot of tweak parameters to account for behavior and geometry of real devices, and parasitics (resistances and capacitances). The tweaks get more numerous, and the models more advanced, as you go up in level (more or less).
A lot of general models available, are in levels 3 and 6, good enough for board-level work; BSIM and EKV are the most accurate (and rich), used by real foundries.
But, good luck getting example models, they're tightly controlled, proprietary! But, if you [or your employer or school] can afford Cadence IC design tools, this is probably no problem. That does leave the question: why haven't you been introduced to SPICE, and the fab's models, yet? You may want to ask!
