What's the point in RF? Won't you be detecting based purely on capacitive coupling until you get to UHF? If it's capacitive any way, might as well stick to audio frequency.
I'd build the one which alternates between 2100 and 2200 Hz. Build the receiver into metal box connected to circuit ground, so your body can provide the capacitance to earth it needs to work when you hold it. Also has the benefit of not being airwave polluting, which seems relevant in the HAM forum.
Yeah I made a TX with a 556 timer, alternating between something like 1200 and 1400Hz, that just attaches to a single wire. For a RX, I'm using my homemade version of Mr.Carlson's Super probe, for AF/RF signal tracing. They work pretty good together, I haven't looked at either one in detail on a scope, IDK how much of higher frequency harmonics from the "square-wave" output of the 556 there is.
But just powering the Super probe from a battery, and the TX from a bench PSU, a lot of signal can couple from me into the probe tip, with it all on the desk anyways. It doesn't work well through the gyproc walls, IDK the physics well enough to know why. But yeah I'll try earth grounding the Super probe next time.
I did add some RF oscillator to the AF TX PCB, with a crystal and CD40xx logic chip, but it never worked. But yeah how much better would some RF signal go through walls ? And then are you saying people would usually use a coil to detect that through a wall ? All that's in my radio books I guess. I should hook one of my working MHz osc. circuits to a dead housewire and see how good my RX projects pick it up with coils. One day I made a big loop antenna to try and estimate the magnetic field strength or mag. flux of a local radio station.
The superprobe picks up 60Hz no problem from live wires, I haven't experimented with how the current affects the volume or anything, but yeah I don't remember the superprobe being able to follow live wires in the walls very good, not with my parts or lack of proper shielding.
