A resistive type is going to provide little isolation by design - even with ideal components it just wont pull it off. What you need for high isolation is something like a Wilkinson power combiner/splitter. This requires one resistor (100 ohm in the case of 50 ohm transmission lines) and a number of transmission line sections of various impedance. If space is an issue, you can also do it with inductors and capacitors (done on chip sometimes).
