I have 2 defective samplers from 83483A / 54751A plugins
( I made one working
plugin from two semi-defective ones) . Part number is Agilent 5086-7699, available as
a replacement part. Someone is selling on ebay for $120 (working with garanty),
somebody else for $160 (defective) and someone for 530 Pounds ("untested", haha).
This is the type of the samplers in the 20 GHz plugin that I used to make the
measurements above.
Repairing the plugins is easy, you just need a Torx bit and a SMA/PC3.5 wrench.
You can just exchange the SMA bricks (really PC3.5), nothing else.
I decided to open one of them. Pictures are what my Sony xpedia Z5 cell phone can do,
but even under the *50 microscope I cannot see all the details. The substrate seems to be
quartz, it is translucent. The squares on the paper are 5mm.
The cavities were filled with absorber foam to avoid waveguide resonance effects.
I think that is outside of the diy area.
