what you need is a driver amp. If interested, look at what I have built for the HF bands:
https://electronicprojectsforfun.wordpress.com/rf-module-gallery/the-amplifier-module-gallery/medium-power-hf-amplifiers/These are "lab amps" that are tolerant to misuse.
BTW, the WA2EBY amp is a counterexample of a good amp design, for the following reasons:
- Its marginal. As Mr. Kossor writes himself, he is running the transistors far out of specs, and he does not expect them to last forever
- Insuffient cooling, cannot be reasonably fixed due to the high Rth of the transistors used.
- Only for AM, no key down CW or FM, or the final transistors will desolder themselves from the PCB under full load
- Misuse intolerant. Overload, missing antenna, wrong output filter, glitches, ... prepare for a new round of transistors
- No protection (High SWR, overcurrent, ...)
As a newbie, I would look for amps that never die, and I would run them only at half of their rated power and cool them well.
Much success !
