I want to build a project that includes a gps module for data logging. For this project i want to use the Ublox M8. There are quit a few ready to purchase modules on the market, but most of them only have supply+uart. I also need the shutdown and pps pin, so i'm considering to integrate the ublox device on my pcb.
For the antenna i wanna use one of these "micro sma (ufl)" connectors and attach a either a ceramic or helix antenna (commercial manufactured antenna). So basically i just want to put the module on my pcb and thenn connect the connector to the module.
But i have a few questions:
1.) Most of the available Modules have a ground plane on the top side and alot of vias to the bottom gnd plane, my guess is that these are just made this way because they are only 2 layer boards. I'm having a 4 layer board with an internal ground plane, so i guess i don't need a ground plane on top or bottom layer, right?
2.) A few modules uses a capacitor/resistor in paralel with the antenna connector, other modules do not. What are these for / when do i need them?
Thanks for your help
