I saw a sneaky solution that someone came up with using a si570 at a frequency of 32-62MHz and mixing it with a 32MHz crystal clocked NE612. You use the LSB as the fundamental and stick a 30MHz LPF on the output. Bit more complicated and probably more expensive but if you don’t have an AD9850 lying around...
Sure, on the other hand, an AD9850 module costs ~$10 on eBay or AliExpress and saves you the hassle.
