As far as I know, there are no special materials involved. Aluminum, Copper, Steel, and plastics. The main contributors to the cost are characterization (pattern and antenna factor at certain frequencies), calibration against a known standard and reaching the required precision for such device (0.1dB tolerance in some cases). Also, it is a very low volume device, so no economies of scale to drive the cost down.
