Toroids are 'self shielding' which is a plus but getting the inductance exactly right with a toroid is not easy because you basically have no in between turn values available.
They aren't, and you do! We're talking VHF here, where you'll be using a few turns each -- squish the turns closer together for more L, or stretch apart for less. The near-field around the individual turns is quite "interesting", not well shielded. It takes a large, evenly distributed winding to get the "self shielding" effect that a smooth, symmetrical toroid has.
(A pot core on the other hand is quite well shielded, but those are hard to come by for VHF purposes!)
