With me moving equipment around, the FM receiver got moved to a location that isn’t very convenient, and thus I need to add a length of coax so I can keep my antennae at the original location. I also want to add a LNA in there in hope to improve reception.
The FM antennae, the receiver and the LNA chip all expect 75 ohm, but my existing coax and connectors are all 50 ohm equipment. I don’t have any 75 ohm coax or matching connectors. FM band in China is 87-108MHz. I build my boards using mostly 0603 SMT passives.
Question:
1. Can I just shove the amplified FM signal from the 75 ohm LNA down the 50 ohm coax and SMA connectors and expect it to work?
2. If not, how to build the matching network on both ends of the 50 ohm coax? Bonus if the matching network blocks DC, since that will also allow me to inject power.
