Huoy!
First off all, I'm new here, I'm an electronics engineer and I love Dave since years
This is a very competent forum, so I hope I get some new ideas to get progress in my project.
Please correct me, when I'm wrong and forgive me that I'm not a RF expert. Any comments and suggestions are welcome.
I want to build a detector to locate lost surfboards. The range could be ~100 m
I'm looking for the most adequate technology to achieve this.
My favorite solution right now is a
passive beacon consisting of a diode and antenna.
Similar to the Recco system. The transceiver need to send a VHF (or UHF) pulse, the beacon will reflect it with the doubled frequency.
The transceiver also contains a receiver with two antennas and is possible to find the direction, since of signal strength.
Pros:
- Beacons will be very cheap
- No battery needed
Cons:
- Water is a problem for RF
- Multiple beacons (no identifier)
- Building the transceiver/receiver could be very hard (actually I could not found any help on this)
GPSPro:
- This could be easy because there a a lot of this devices on the market
- No need of a detector
Cons:
- It will need a SIM Card and Network connection. This will be a problem for travelers
- Water, when the board is upside down, I'm pretty sure no connection will be possible
Bluetooth (low energy)
Pro:
- A lot devices (chips) on the market
- No detector needed (smartphone)
- Direction is not given
Cons:
- The range might be very low
- Battery
Active RF transmitter:
Pro:
- Good range (at least I think so)
Cons:
- Without an activation mechanism, the battery will die very fast
- Receiver and transmitter is hard to build
Again: Thank you in advance
