Dear signal processing experts,
I am planning the development of an aeronautical test transceiver. One of the signals to be supported is the future standard of LDACS1. It operates in FDD mode, in the aeronautical L-Band (around 1 GHz). The modulation is OFDM, with 50 sub-carriers and a symbol duration of 120 microseconds. The occupied bandwidth is 500 kHz.
With the bandwidth being fairly narrow, I am debating the modulation and demodulation approach. The conventional analog zero-IF architecture with dual converters and a quadrature (de)modulator seems overkill. We would also need to deal with DC offsets and I/Q imbalances.
The alternative would be to use a single ADC or DAC respectively and do the (de)modulation in software (FPGA, Xilinx Zynq). In theory that should work. But are there any practical downsides to this approach?
Many thanks for your inputs.
Martin
