I think it monitors the power out of the A400 module, which eventually goes to port 1. Here is a jury rig, pict6885 I fitted one of those Russian 3A121A GaAs detector diodes that are supposed to be good for 40GHz. shorted inputs together, pict6886 it sort of works !. In the service menu, pict6889 is the good detector, pict6890 is the jury rig one. pict6893 is a 3GHz LPF fitted between measuring ports. sort of usable !!!
Ken
