Author Topic: L-Network Question  (Read 1318 times)
Offline rcbuckTopic starter
L-Network Question
« on: March 15, 2018, 11:40:52 pm »
I have been playing with L-Network matching circuits. Is there a formula that can be used to absorb the load series capacitor into the L-network?
For instance, in the attached schematic, assume the load is a crystal filter with an impedance of 210 ohms. The source impedance is 50 ohms as indicated. The design frequency is 9.0 MHz. I want to absorb the 88 pF cap into the L-network as that is one less component to deal with. The values shown for the L-network assume the load is 210 ohms including the 88 pF series capacitor.
Edit: Forgot to add schematic jpeg
« Last Edit: March 16, 2018, 12:38:00 am by rcbuck »
Offline Neganur
Re: L-Network Question
« Reply #1 on: March 16, 2018, 10:24:21 am »
Is C2 Part of the crystal?
Do you happen to have the part number of the crystal?
« Reply #2 on: March 16, 2018, 02:50:31 pm »
No, C2 is not part of the crystal. It is the series resonating cap that changes the frequency of the first crystal in the filter. The part number of the crystal doesn't matter.
Offline yl3akb
  • Country: lv
« Reply #3 on: March 16, 2018, 04:08:32 pm »
I like graphical approach better, when it comes to matching these circuits. Of course, You can absorb C2. L1,C1 and C2 transforms 50 ohms to Z = 209-j199 ohms. The same impedance can be obtained with L1=2.34uH and C1=160pF. See Smith chart graphs how it is obtained.
« Reply #4 on: March 16, 2018, 05:36:51 pm »
yl3akb, thanks for that reference. I knew it could be done with Smith chart. I was hoping there was a formula (or formulas) that would work.
I tried using SimSmith to perform the task. But I kept coming up with numbers that I knew were wrong. I guess I need to learn how to use Smith chart. I know W2AEW has few youtube tutorials on how to use it.
Offline KJDS
    • my website holding page
« Reply #5 on: March 17, 2018, 06:04:17 pm »
The formulae are given in Rhea's Yin and Yang of Smith chart matching.
