Author Topic: LDMOS Amplifier Construction  (Read 1774 times)
Offline German_EETopic starter
« on: August 06, 2017, 01:03:40 pm »
A series of eight YouTube videos on the construction of a high power LDMOS amplifier.
This fellow must be very brave or a single man because he joins the two halves of the heatsink together using solder paste and the heat from his electric cooker. If I tried this SWMBO would have words. Also, those transistors are 177 Euro each from Mouser.
« Last Edit: August 06, 2017, 01:08:28 pm by German_EE »
Warren Buffett
Offline David Hess
  • DavidH
Re: LDMOS Amplifier Construction
« Reply #1 on: August 06, 2017, 05:30:41 pm »
I have done the same thing using normal flux cored solder and a cutting torch head to get enough distributed heat but the electric cooker probably yields better results.  I assume the real pros use an argon filled electric furnace.
Offline BigBoss
« Reply #2 on: August 06, 2017, 07:01:55 pm »
I believe that he'll pay a electricity invoice very badly.. ^-^
