Hackaday
"What makes LimeSDR interesting is that it is using Snappy Ubuntu Core as a sort of app store. Developers can make code available, and end-users can easily download and install that code."
Electronics Weekly
"Crowd-funding changing the game for chip firms"
Microwave Journal
"Learn and test new communications techniques, unleash new applications and open up new markets using the powerful LimeSDR platform"
Electronic Engineering Journal
"...a low cost, app-enabled software defined radio (SDR) base station that can be programmed to support any type of wireless standard – putting significant power at the disposal of anyone who wants to innovate in the world of wireless"
EE Times - Europe
"Lime Microsystems have built a wide range of open source support tools and resources...from the outset"
Wireless - Electronic Specifier
"Create and deploy wireless network infrastructure almost anywhere at a fraction of today’s costs"
Features & Specifications
RF Transceiver: Lime Microsystems LMS7002M MIMO FPRF (Datasheet)
FPGA: Altera Cyclone IV EP4CE40F23 - also compatible with EP4CE30F23
Memory: 256 MBytes DDR2 SDRAM
USB 3.0 controller: Cypress USB 3.0 CYUSB3014-BZXC
Oscillator: Rakon RPT7050A @30.72MHz (Datasheet)
Continuous frequency range: 100 kHz – 3.8 GHz
Bandwidth: 61.44 MHz
RF connection: 10 U.FL connectors (6 RX, 4 TX)
Power Output (CW): up to 10 dBm
Multiplexing: 2x2 MIMO
Power: micro USB connector or optional external power supply
Status indicators: programmable LEDs
Dimensions: 100 mm x 60 mm
Block Diagram
Comparisons
HackRF One Ettus B200 Ettus B210 BladeRF x40 RTL-SDR LimeSDR
Frequency Range 1MHz-6GHz 70MHz-6GHz 70MHz-6GHz 300MHz-3.8GHz 22MHz-2.2GHz 100kHz-3.8GHz
RF Bandwidth 20MHz 61.44MHz 61.44MHz 40MHz 3.2MHz 61.44MHz
Sample Depth 8 bits 12 bits 12 bits 12 bits 8 bits 12 bits
Sample Rate 20MSPS 61.44MSPS 61.44MSPS 40MSPS 3.2MSPS 61.44MSPS (Limited by USB 3.0 data rate)
Transmitter Channels 1 1 2 1 0 2
Receivers 1 1 2 1 1 2
Duplex Half Full Full Full N/A Full
Interface USB 2.0 USB 3.0 USB 3.0 USB 3.0 USB 2.0 USB 3.0
Programmable Logic Gates 64 macrocell CPLD 75k 100k 40k (115k avail) N/A 40k
Chipset MAX5864, MAX2837, RFFC5072 AD9364 AD9361 LMS6002M RTL2832U LMS7002M
Open Source Full Schematic, Firmware Schematic, Firmware Schematic, Firmware No Full
Oscillator Precision +/-20ppm +/-2ppm +/-2ppm +/-1ppm ? +/-1ppm initial, +/-4ppm stable
Transmit Power -10dBm+ (15dBm @ 2.4GHz) 10dBm+ 10dBm+ 6dBm N/A 0 to 10dBm (depending on frequency)
Price $299 $686 $1,119 $420 ($650) ~$10 $299 ($199 early bird)
