How would an external USB sound card (Via vt1620a based) that is advertised in the chipset data sheet as supporting 192 KHz sampling, but which only enumerates as 96 kHz capable, be told, under Linux to use the full 192 KHz?
Basically that would enable a doubling in SDR bandwidth with this very cheap but good performing external sound card - that would likely please a lot of people.
Currently its working great, though at 24 bits@96 kHz.
