I remember when that active circulator article was first released and have it in paper form.
The AD8009 is a fine choice with both higher bandwidth and higher output current then the CLC406 which is also a current feedback operational amplifier. Note however that the physical construction and layout is more important as the frequency goes up so it may be better to use a slower part initially.
