janejm,
Dust uses something like 5-10 uA IIRC to keep the network alive and healthy, and remember that the whole network could be switched off, or parts of it selectively, when not in use. Maybe the whole mesh network would only be powered an hour per week. So mesh isn't necessarily a huge battery drain, but it does make battery life somewhat unpredictable, since some nodes would take a higher load than others, even with the network trying to distribute load evenly. Mesh will also have some advantages, possibly resulting in lower total energy, and that's the kind of thing I'm trying to get suggestions for.
WiFi is an interesting idea. WiFi is already available in parts of the structure. I'm sure it would require multiple base stations to cover the entire area, all to be mains powered, and that would require extensive cabling, which I would like to avoid.
mikeselecticstuff,
Yes, the base station is mains powered with no special requirements.
Actually, since the radios can be powered down when not in use, I would say that the standby power could be the least important factor, if it turns out to be most advantageous to do (and it probably will I think). And regardless of how low energy the various solutions are, and how low my duty cycle is, it will always be a good thing to save money on a smaller battery by achieving the very lowest energy consumption possible. A possibility I haven't mentioned is also to run off vibration harvested energy. I didn't want to muddle the question with that, since the benefit of lower energy consumption is the same (lower cost), and the power delivery requirement challenges are similar, but low power is even more important for vibration harvested energy (cost of the harvester). I have examined that extensively.
The power vs. energy trade-off is a very good point, and I have been thinking about that myself. I have designed a combined battery/harvesting systems before, where I used supercaps for the harvesting, and where the primary battery used could handle the radio (Wireless M-Bus) current draw when running on battery. I think it was 40 mA. Power/current delivery shouldn't be a problem, but passivation might indeed. That will have to be analyzed by a battery manufacturer.
