The radio is powered by the same 12V DC output wall transformer, as the oscillator circuit
I am using a Byrmen 869, which does not have very consist frequency measurements at any range it seems, I can read freq. from a few dail settings with this thing, and they often don't match, because some will read zero
for instance on AC+freq, I read 1.5257V and 0.000Hz yet if i switch to mV(AC)+Hz I get 748.0kHz(it changes a lot)
thats about what it should be by the equations
this little 1/4W inductor gets warm
So I guess its the changing conductance of the transistor, thats changing at is also modulated, and sometimes drops into AF and I hear it
