Every bit of loss before the LNA raises the noise floor by the amount of loss. So a 0.3db nf LNA with a matching network that has 1db of loss will come out to a nf of 1.3db. If your loss in a matching network is higher than the mismatch loss of it not being present, then you aren't helping more power go into the amp itself. And being right at the noise floor you're fighting for every last bit of energy to get stuffed into your gain element. If you're adding a resistive match to transfer more energy out of the antenna, just to burn it up in the resistor, unless it's serving some other purpose, why even bother?
Getting an amplifier set up is an exercise in compromise. (Gain, noise figure, bandwidth, input/output matching, current draw, PAE, p1db, linearity) make sure you're compromising in the right areas for the task.
As Tim said above, max gain/power is usually close, so once the first order approximation is out of the way you can work on the finer details.
