It helps that it's narrowband.
Good thing "this guy" didn't know either,
But as you can see, it takes quite some drive:
(It's also rather inefficient, but class A and AB is desirable for a low distortion wideband amplifier.)
This is why I suggest using something else. They're not as easy to use: low gain, lots of capacitance, lots of lead inductance.
Not that a gazillion 2N3904s in parallel is any better, but you should hope for something intermediate that's, say, the size of a TIP29 for instance, but still has the speed of a bunch of 2N3904 in parallel.
The suggestion of BD139 is quite good, if you can find one that's actually specified for fT and such. Sadly, the base spec is more basic than a 2N2222! *scoff*
CRT video output transistors may be of use. I used a pair in the above amplifier. Audio amp VAS (voltage amplifier stage) transistors would be good too, if they're fast enough (again, common choices like MJE340 don't happen to be rated for AC performance, what a ripoff).
(Ed: oh yeah, that's the one: I have a couple 2SC2690A's that are rated quite favorably. Superb for VAS duty, or for a modest SW RF amp!)
Commodity MOSFETs are pot luck. Even the humble 2N7000 has quite a low impedance: a current capability of 100s mA, and 30pF+ of capacitances. It rolls off slowly above 20 or 50MHz, and needs ever lower supply voltage and source/load impedance. It's been said it can switch as fast as fast as you can drive it; but therein lies the problem, you can't drive it faster than maybe 200MHz, at any reasonable sort of impedance (it needs as little as a few ohms up there), and still expect overall gain.
And not that a stack of 2N7000s is any better than a stack of 2N3904s, but the point is it's
worse: lower impedance and gain. And this behavior will be typical of most commodity MOSFETs.
The irony is, if you go out of your way and buy a proper RF MOSFET, they're
orders of magnitude faster, like two of them. You could put together a single stage 27MHz amplifier that does the job (well, maybe not single, but two stages for sure), but now you have to worry about parasitic oscillations over 1GHz!
