Author Topic: Measuring sub Pf capacitances  (Read 5339 times)
Offline jusanotherTopic starter
« on: May 24, 2018, 11:18:45 pm »
I have bought some nasty Chinese 1.3Ghz video transmitters and receivers (due to a lack of alternatives). As a rule I usually whip the case off such items just to check the construction, usually the machine assembled bits look fine but anywhere a human has been involved (connectors, shields, thru hole parts, bodge wires, etc.) the quality can go down hill dramatically. On one of the receiver tuners there is a component missing, looked like it had been knocked off the board. On opening another identical tuner it looks like a capacitor, I have removed it and tried to measure it but the capacitance is so low I am looking for a way to verify it.
I measured it using one of these by Phil Rice VK3BHR and it comes up as 0.6pF, it is repeatable but god knows how accurate this meter is at this level of capacitance. (Buying a 0.6pF cap and checking it would be a fair comment)
I considered buying a Mastech MS5308, I know overkill for one measurement but it doesn't look like the accuracy would be the best. This post is the nearest I can find, it is just a breakdown of the official spec not an actual test.
So the question is what tricks are there to figure out the value of this capacitor given it's potentially low value ? I have a digital scope, multimeter and other basic equipment. This simple Femto Farad circuit looks interesting.
I also realize that there is potential for this value to be a calibrated/compensated for value but I don't know enough about tuner topology to figure that out so I was going for the get it as close as I can and try it approach. Plus the only trimmed component I can see in the tuner is an air cored inductor and in several tuners the trimming looks very similar, which granted may be a good or bad sign. Good - the construction is so tight the trimming is all similar, bad - they just make it look like they trimmed something but the device never gets powered, granted the latter is more likely.
Offline RadioNerd
Re: Measuring sub Pf capacitances
« Reply #1 on: May 25, 2018, 02:30:32 pm »
You could build an LC resonator (tuned to 20 MHz or so) with a wire loop coil and a few 10pF resonator capacitance... the shift in resonance frequency will tell you the value of the unknown capacitor when you add it in parallel to the resonator capacitor.
To measure the resonant frequency you can exite the resonator using another coil loosely coupled (i.e. not too close) to the main coil.
You will need a signal generator for that, though.
Offline Terry01
  • Country: scotland
« Reply #2 on: May 25, 2018, 02:53:58 pm »
There are quite a few videos on YouTube on how to measure the value of a cap with a scope.
Do you live near any other members on this site who have an LCR meter or DMM that can measure down to pF? If your going to the bother to buy an LCR meter for just 1 measurement it may be easier and less expensive to post the cap to another member who can measure it for you.
Hope you get something sorted buddy.
Sparks and Smoke means i'm nearly there!
Online Kleinstein
« Reply #3 on: May 25, 2018, 03:16:51 pm »
Measuring small capacitance is not that difficult. The tricky part is more in how to hold / connect the capacitor than in measuring the relatively small AC current. The parasitic capacitance towards the capacitor can be in 0.1 pF range.  So the capacitance not only depends on the part but also on the layout around the part.
The usual bodge solution to get 0.6 pF is to have 2 strands of the flat cable and than use about 1 cm per pF, thus about 6 mm.  This also makes a nice trimmer. In some cases a piece of insulated wire on top of a track is another option.
« Reply #4 on: May 26, 2018, 12:12:35 am »
@Terry01 I have watched a few videos on measuring capacitance with a scope, most of them don't venture into the single pF region and I did read mention that the probe capacitance might be a limiting factor which you would have to compensate for, just not sure if that would work given the probes capacitance is going to be 20-30 times larger than what I am measuring ? As to buying a meter for one measurement, what can I say, he who dies with the most tools wins, right ? I hadn't thought of posting the component to someone more suited basically because I don't know anyone, but it's an excellent idea, I just need a willing helper. I do have a Knight  K-240C LCR meter but the measurement is lost in the noise, the DIY meter produces more repeatable measurements.
@ RadioNerd I had read about such a delta observation practice and although I don't own a signal generator I think it's a more sensible purchase than a LCR meter.
@ Kleinstein So with twisted strands I could at least check my current measurement ?
So at least you guys have confirmed it's not a totally trivial task and pointed me in some useful directions, thanks !
Offline Wolfgang
    • Electronic Projects for Fun
« Reply #5 on: August 27, 2018, 11:10:46 pm »
I do it on a VNA. I take an SMA flanged socket and solder the component from center to flange. To normalize, I use a new connector without anything attached.
The capacitance can be read from a Smith chart then.
Like here:
https://electronicprojectsforfun.wordpress.com/componentology/
« Reply #6 on: August 29, 2018, 11:20:03 am »
Interesting link, I had been considering one of the XAVNA's strangely enough. Never crossed my mind to use it for this task but as you say it can be done.
Offline qu1j0t3
« Reply #7 on: November 05, 2018, 12:47:20 pm »
Does anyone know how to contact Phil? All the resource links (images, source code) on that site are now 404.
TIA
« Reply #8 on: November 06, 2018, 12:02:40 am »
Weird, just checked them 2018.11.06 00:02 GMT and they are all working. Check em again, if not I can download and share.
The following users thanked this post: qu1j0t3
Offline qu1j0t3
« Reply #9 on: November 06, 2018, 12:05:00 am »
Ah, I see what the problem was... I was looking at the old version, not v2. I didn't realise there was a v2! Double thanks.
The following users thanked this post: jusanother
Offline seebeck
  • Country: cn
« Reply #10 on: November 06, 2018, 11:02:36 am »
If you want to measure a 0.xpF capacitor, you need to use a RF LCR meter such as Agilent 4287A (3GHz).
Offline G0HZU
« Reply #11 on: November 07, 2018, 02:12:45 am »
You could also do it with a UHF oscillator. eg make a negative resistance oscillator up at a GHz or so that looks like -10R in series with a couple of pF. Then the addition of the 0.xpF cap across another external cap (in series with a tiny resonator inductor) will change the frequency of the oscillator slightly. It wouldn't be difficult to characterise it if you bought a few 0.xpF caps of known value. It would cost about £1 in parts and be quick to make if you made an ugly prototype but a neater version would go in a nice test fixture.
« Reply #12 on: November 07, 2018, 09:59:56 am »
It’s extremely difficult measuring capacitors that low without expensive kit due to fixture/probe and even placement capacitance. I genuinely wouldn’t bother.
I would buy a few small caps around the estimated value and make measurements once they are substituted in and pick one that has the desired outcome. This of course assumes you have measurement equipment to cover the desired outcome.
G0HZU’s method is probably most accurate (that’s what I use) but that still suffers from oscillator drift and temperature effects. You have to leave some oscillators an hour or more after soldering to settle down. Even the placement of the fixture on the bench can be a problem!
Sometimes working out how to avoid making the measurement is more cost and time effective :)
Offline Wolfgang
« Reply #13 on: November 07, 2018, 11:18:33 am »
In these cap ranges, a super-well-defined geometry is everything. I would say that measurements below half a pF without a precision test fixture are unreliable. If it has to be exact, you need a VNA with APC-7 attached precision fixtures. AND you need a big wallet :)
Online PA0PBZ
« Reply #14 on: November 07, 2018, 11:48:03 am »
I wonder if the cap was removed during 'trimming' because it was no needed/worked better without. Did you ever check the receivers performance?
The following users thanked this post: wraper
Offline wraper
  • Country: lv
« Reply #15 on: November 07, 2018, 12:57:08 pm »
Exactly, on the photo it does not look anything like knocked off. It was just desoldered.
« Reply #16 on: November 07, 2018, 08:27:03 pm »
I think that photo was from the second tuner I removed the cap from to test. The original tuner with the missing cap had very definitely been knocked off, you could clearly see the component outline in solder. Whether it was knocked off as part of the trimming procedure didn't occur to me, I forget how rough some Chinese manufacturing can be. Another member here used a DER EE DE-5000 to measure the cap in question and got it at around 1pF (my meter reckoned 0.6pF), this appeared to work when re-fitted although I haven't tested the unit to the limits or against a factory "good" one.
« Reply #17 on: November 07, 2018, 08:36:37 pm »
Apologies for asking but my RF kungfu is weak, do you have an example schematic you could point me at ?
Offline G0HZU
« Reply #18 on: November 07, 2018, 11:09:13 pm »
Sure, but do you have something that can measure frequency up at 1GHz?
The ideal thing would be a spectrum analyser but a cheapo USB SDR dongle (with a simple RF probe antenna)  that can work up at a GHz and give a slow scan of maybe 800-1000MHz would be adequate I think. You would also need some caps to calibrate it with although this isn't strictly necessary if you build it right. If you don't have the above frequency measuring device then there isn't much point making the circuit :)
It would take just a few minutes to make it and test it but you would need a decent RF transistor (eg BFR91 is easy to work with but a BFR93 SMD would be OK). Also a decent 1pF and 1.5pF SMD cap and a bit of spare PCB and a couple of basic resistors at maybe 1k and 47k (don't have to be SMD). It would also need an SMD inductor of about 33nH but you could make this yourself.
It should give about a 50MHz shift in frequency with 0.4pF added so it would be OK to solder the test cap in place as long as you don't mind waiting for a couple of minutes for it to cool. Otherwise, you risk pinging the SMD test cap into outer space if you press it in place with an insulating tool.
It should be good enough to measure caps at 1GHz across several pF to maybe 0.2pF with good results. If you have an SDR or a spectrum analyser I'll post up the circuit and maybe build an example for you to copy. It works fine on a simulation and should work well in reality as it's only 1GHz. Total cost maybe £1.
« Last Edit: November 07, 2018, 11:11:51 pm by G0HZU »
« Reply #19 on: November 07, 2018, 11:20:07 pm »
I do have a cheapo SDR and a SSA3021 spectrum analyser (call it a splurge into the land of learning RF), so your help will be gratefully learned !
Offline G0HZU
« Reply #20 on: November 07, 2018, 11:34:13 pm »
Here's the circuit so you can see if you have these parts. The transistor needs to be something decent and if you can get a genuine BFR91 it will be easy to work with because it is in a nice pill package. The other parts are non critical but the caps need to be SMD. The resistors don't nee to be SMD. C5 in the circuit is the cap under test. The ground connections need to be very direct and because you only need this for one task there is no need to make a proper PCB.
Can you get hold of an old school BFR91 transistor?
Don't build it until I've made one to show you how to do it easily and neatly. Don't expect lab grade precision but you should be able to get a good idea of the capacitance of your cap for a very low cost in time and parts. If you need to buy a few parts then maybe best to buy a few SMD caps in 0.2pF steps but you probably don't need to go to this extreme. Maybe just buy a few test caps, maybe 1pF, 0.5pF and 0.2pF.
Note that it runs from a negative supply of -9V. It is done this way to keep the circuit very simple and easy to make on a bare sheet of copper PCB.
Offline G0HZU
« Reply #21 on: November 07, 2018, 11:40:15 pm »
It's probably easiest if I build one, test it and pop it in the post to you because we are both in the UK? The build cost to me is nothing. I have loads of surplus RF parts here.
« Reply #22 on: November 07, 2018, 11:44:09 pm »
If your sure that would be great. I was just about to post a link to eBay for the BFR91's as neither RS nor Farnell have them but I am guessing you knew that already :)
Offline G0HZU
« Reply #23 on: November 07, 2018, 11:49:59 pm »
Yes, it's hard to get genuine BFR91s nowadays. I have a large bagful of them that are over 25 years old. Give me a day or two to make a tidy version and have a play with it. I've also got plenty of 0603 caps in 0.1pF step sizes here.
« Reply #24 on: November 08, 2018, 12:01:00 am »
Brilliant, what can I say, thank you.
