I'm making a little 5 BJT MT
The coil I made is 19.4uH at 100kHz w/ 25.7Q , and I have that Colpitts oscillator working after upping the gain by changing C2/C1.
I'm using an 8MHz crystal, and I manged to get it working after upping the base resistor to 680k and the base cap to 1n.
Without the coil or crystal on the breadboard, the mixer works great as a radio for a local 800kHz station. You can barely hear it until I touch my finger on either base resistor of the mixer, and then it's sound great just from the piezo.
So now both oscillators are working, and if I place a 2.5lb plate weight over the coil, the Colpitts will drop most of it's amplitude. And on the mixer output, there's a complex but repeating wave at the 1.2MHz of the colpitts. And it changes around when the weight is on the coil.
But there's no audio frequency at all, I don't see anything that seems like ultrasonic or up. But IDK, glad I made it this far.
In the guys video he had about 2:1 between osc. Mine is basically random, 8MHz to 1.26MHz = 6.35
In this type of MT, what is it that makes the audio frequency when they mix ? Should I try for 2:1, what about 3:2
What does the ratio really do ?
For all I know there's a nice ultrasonic sound there
