Author Topic: Microstrip bending in a transformer  (Read 2538 times)
Offline i_am_mryTopic starter
  • Country: ru
« on: September 14, 2017, 08:55:35 am »
Hello all,
I'm creating microstrip  50-to-75 ohm wideband transformer. Here is my draft:
And my questions are:
Can i bend quarter-wave parts?
Is there any shortening factor for the each bend?
Offline T3sl4co1l
    • Seven Transistor Labs
Re: Microstrip bending in a transformer
« Reply #1 on: September 14, 2017, 11:56:34 am »
What do you mean "bend"?  As in, turning corners, in the PCB layout?
Use arc segments (trace length = mean arc length), 45 degree corners (close enough not to worry about), or 90 degree corners with a chamfer (trace length follows the inside path).
I doubt the quarter-wave lengths are very critical: your bandwidth is quite large (>50%).  Can always design it for extra bandwidth (the result will be a couple extra steps), to get even looser tolerances.
Note that the trace edge-to-trace edge distance should be 2-3 trace widths minimum.
Seven Transistor Labs, LLC
Offline Yansi
  • STM32, STM8, AVR, 8051
« Reply #2 on: September 14, 2017, 12:04:58 pm »
Why not using a tapered transition instead of the stepped one?  Doesn't the taper give more bandwidth naturally?
  • Country: ru
« Reply #3 on: September 14, 2017, 01:29:00 pm »
Hi Tim, Thanks for detailed answer.
Yes, just the turning corner, to make PCB more compact.
As i understand, in this case "inside path" will be summary length of red edges. Is it correct?
Thanks for a tip. I'll look on it.
