Author Topic: need help matching chip antenna M620720  (Read 310 times)
Offline bug13
« on: November 28, 2017, 03:30:41 pm »
Hi guys
I have done a couple PCB antennas matching, but I have trouble matching this chip antenna M620720 with a PI network to 50ohm:
M620720 https://www.ethertronics.com/wp-content/uploads/2016/11/M620720-ISM-868-915MHz-Ethertronics-Savvi-Ceramic-antenna-datasheet-20161020.pdf
I found an example in this developer guide:
Multitech xDot https://www.multitech.com/documents/publications/manuals/s000645.pdf
In P33, they use two caps? I don't understand this configuration, can someone give me some pointers? Thanks a lot!
PS:
  • I am able to turn the frequency with the minor and major turning, but with no luck matching it 50ohm.
    I only have a USB desktop VNA
« Last Edit: November 28, 2017, 03:33:42 pm by bug13 »
Zhuhua Wu
Electronic Engineering Student
