Thank you very much for your replies.
The NPTB models don't match the transistors, so designing matching networks becomes little more than guesswork.
I don’t understand what is “NPTB models” and why should they match the transistor. Did you mean that this NPTB00004A is not internally matched?
Your problem is going to be matching the discrete output stage from 2 to 4 GHz. You are using the datasheet numbers for 2.5GHz. You will get much lower gain at 4GHz. Those numbers are also the optimum for single frequency. Broad band you will have degraded performance.
Well, yes, I understand this. But I simply failed to find any another non-obsolete output active device within this band and power. I searched on Mauser and Digikey. There is yet
HMC7885 but it costs 10,000 dollars which is unacceptable.
The package parasitics are going to make it difficult to get good broadband performance. There is a reason people use chip and wire for broadband discrete power amplifiers. You would be better off using a MMIC for the output stage. (Except for the cost of course.)
I don’t understand some of this. Package parasitics are parasitic capacitances and inductances which are too high in this particular NPTB00004A package? Did I get it right? And “wire” is a sort of RF conductor medium which has round cross-section? It is more fitting to a broad band transmission than a convenient planar PCB lines? Right?
The '637 is a wire bond bare die sort of affair, are you really set up to mount that (In a way that gets the heat out)?
Well I didn’t think about it yet. Am I getting it right that this die demands very special techniques and equipment to mount, heat sink and keep working in comparsion to standart packages, right? I have no idea how complicated it can be so I maybe find some more convenient package if this ones demands too much efforts.
Package parasitics will kill you for broadband matching those output devices over a full octave, and in any case consider the thermal issues, they would be right on the ragged edge @ 10W.
Could you please specificate what parasitics and what particular package do you mean? And what “ragged edge” do you mean? The edge of HMC637 die faced towards quadrature coupler or what?
I would be reaching for something with at least partial internal matching, ...
What is “partial internal matching”? How is it possible? As far as I know device is whether internally matched or not. Can you please give me a part number or a link to such partially internally matched device?
...and then printing a few hairpins or stubs or something to get what I needed in terms of gate match, and careful selection of final supply rail will let you set the resistive part of the drain impedance to 50R @ 10W which may prove convenient.
It’s about input and output matching networks of output power amplifier? Gate match = input match; drain match = output match?
Does it refer to my NPTB00004A transistors or to some another device which I should pick instead of NPTB00004A?
W1GHZ has a paper "Simple Broadband Solid-State Power Amplifiers" which discusses the use of resistive feedback to get the input impedance of GaAs fet amplifiers in the low microwave, it may be useful.
Nice document, I found it useful.
I’m sorry for asking silly questions, I’m only making my first steps in RF design.
