it is indeed true that measuring impedances that are either very small or very large present an accuracy problems for a VNA.
Several strategies exist:
- If you know where to look, you could employ specialized measurement techniques like shunt-thru or series.
With these, you could measure PDN impedances in the milliohm range or the impedance of Quartz crystals.
Keysight has very good app notes on this topic, and a specialized machine like the E5061B-3L5.
- Buy a better VNA. The better ones have a broader range, more accuracy and less tolerances.
In extreme cases, impedances of 0.1Ohm or some kOhm can be measured.
- Do not forget to buy extremely good, phase stable cables and a pro cal kit.
Intelligence can beat blunt money in a lot of measurement tasks.
