Author Topic: Now We Wait For The CME  (Read 2249 times)
Offline AF6LJTopic starter
« on: September 06, 2017, 01:12:28 pm »
X-9.8 solar flare this morning, this is going to play hell with HF radio communications.
Sue AF6LJ
Re: Now We Wait For The CME
« Reply #1 on: September 06, 2017, 06:09:03 pm »
This is a big deal....
From Spaceweather.com.....
MAJOR X-CLASS SOLAR FLARE: On Sept. 6th at 1202 UT, sunspot AR2673 unleashed a major X9.3-class solar flare--the strongest solar flare in more than a decade. X-rays and UV radiation from the blast ionized the top of Earth's atmosphere, causing a strong shortwave radio blackout over Europe, Africa and the Atlantic Ocean (blackout map). The explosion also produced a CME. However, available coronagraph images are not yet sufficient to determine whether or not the CME is Earth-directed. Please stay tuned for updates about this event.
http://spaceweather.com/
Sue AF6LJ
The following users thanked this post: voltz
Offline voltz
« Reply #2 on: September 07, 2017, 02:43:16 pm »
Currently experiencing a complete HF blackout here in the UK. 160 to 10, all dead. (time now 15:40 local time).
http://hackgreensdr.org:8901/
« Reply #3 on: September 07, 2017, 02:53:32 pm »
Not so good here also..
Sue AF6LJ
Offline voltz
« Reply #4 on: September 07, 2017, 03:19:44 pm »
Starting to hear signals again now. That was one serious drop out.. Could not hear a single station, not even on CW. So seems to coming in waves. That last one lasted about 20 minutes or so.
« Reply #5 on: September 07, 2017, 04:42:27 pm »
Wow we just had another large one...
http://www.swpc.noaa.gov/products/goes-x-ray-flux
Sue AF6LJ
« Reply #6 on: September 07, 2017, 05:33:01 pm »
Well at least I've got an excuse for my home brew receiver being crap today!
Offline CopperCone
  • *knock knock*
« Reply #7 on: September 07, 2017, 07:12:21 pm »
Is it too late? I just finished making a magloop for HF. Is there a particular characteristic you can detect of the solar flare with a HF antenna?
« Last Edit: September 07, 2017, 07:16:15 pm by CopperCone »
Offline ruffy91
« Reply #8 on: September 07, 2017, 07:21:22 pm »
We had a DAB+ Blackout on 194.064MHz for a few hours. Could this be from this solar flare?
« Reply #9 on: September 07, 2017, 08:21:17 pm »
Signals go away, and when they are really bad the normal band noise (not caused by power lines or other strong local noise sources) will actually go down in amplitude.
Sometimes AM broadcast stations will be attenuated.
The effects are not seen during the night hours, however the disturbance caused by a CME can be very disruptive during both night and day.
Sue AF6LJ
Online PA0PBZ
« Reply #10 on: September 07, 2017, 08:24:23 pm »
No, the effect is on the ionosphere and influences radio waves that are normally reflected by the different layers there. Line-of-sight communication (generally everything above 30-50Mhz) are not affected.
The following users thanked this post: AF6LJ
