Author Topic: Post your Call Sign  (Read 24078 times)
Offline KD0CAC John
Re: Post your Call Sign
« Reply #50 on: March 02, 2016, 03:26:06 pm »
Posted since I been here ;)
Offline KC9FJE
« Reply #51 on: March 04, 2016, 08:54:37 pm »
My username is my call so no hiding that one haha
12 years as a ham, nearly 1.5 as an Extra class. Mostly a digital mode operator (heavily favoring JT65 and WSPR) I tend to dabble more with guitar effects/amps than RF though in my free time but enjoy working with both. I'm currently working security overseas while knocking out my BSEE so I can make the jump to the electronics design field.
With any luck I'll get my YI call and get back on the air, until then I'm stuck to operating remotes.
Offline borjam
  • EA2EKH
« Reply #52 on: March 04, 2016, 09:58:06 pm »
EA2EKH here.
Exam passed in 1989, applied for call sign a year ago :) (long story).
Anyway, finally!
Offline NF6X
    • Mark's Green Pages
« Reply #53 on: March 05, 2016, 10:04:40 pm »
NF6X here. I play with old military radios, and I am active in the West Coast Military Radio Collectors Group. In fact, I'll be running our weekly AM net on 3985 at 19:00 PST tonight if I can get my big T-368C transmitter working again. I had it apart to deal with an issue of arcing on voice peaks, and I did something in the process that messed up the modulator plate current. Fun with high voltage and 60 year old wiring!
Offline cadamei
VK4HEX
« Reply #54 on: March 06, 2016, 12:11:12 pm »
I started a EE degree after finishing high school, but I dropped it a year later. Now 7 years on and I'm trying to tech myself what I didn't finish.
My current dilemma is choosing between an oscilloscope and an SDR.
See you all around.
cad
Offline Dave Atom
« Reply #55 on: March 14, 2016, 12:02:50 pm »
G6FFB here, not been active for a while but licence is still current :)
Magic smoke detector Out of Order, please switch on with extreme caution.
Offline Kohanbash
    • Robots for Roboticists
« Reply #56 on: March 14, 2016, 09:45:00 pm »
KB3RMP. Mostly local VHF/UHF in Pittsburgh, PA
Robots for Roboticists Blog - http://robotsforroboticists.com/
Offline AF6LJ
« Reply #57 on: March 14, 2016, 10:22:55 pm »
Oh Dear; good luck getting that beast back on the air.
Sue AF6LJ
Offline Nickolaos
  • Country: gr
« Reply #58 on: March 24, 2016, 08:49:39 am »
Greetings from Greece.SV6RDF.I am a post graduate electronics engineering student from Greece
« Last Edit: March 24, 2016, 08:52:56 am by Nickolaos »
Offline F6DEX
« Reply #59 on: March 25, 2016, 10:04:23 pm »
Hello from F6DEX Laurent
Offline ytterligare
« Reply #60 on: March 30, 2016, 10:03:35 pm »
I3APR here in jn55mk, from Verona, Italy  :bullshit:
Offline kayaks
« Reply #61 on: March 30, 2016, 10:38:14 pm »
WL7CG in Valdez, Alaska. Ops mostly HF digital modes.
Offline ArdRhi
    • Jenny Everywhere's Infinite: Quark Time
« Reply #62 on: April 13, 2016, 10:11:45 pm »
NG3P here, near Valley Forge.
When I saw a 2x1 with my initials was available, I grabbed it!
Gwen, NG3P                   Author, Cartoonist, Hobbyist
Valley Forge, PA area
Offline JStevensAB9JS
« Reply #63 on: February 09, 2017, 07:51:33 pm »
"73"
   John AB9JS
Offline Johncanfield
« Reply #64 on: February 09, 2017, 10:53:53 pm »
QRZ..
John, WB5THT in central Texas. First licensed in 1964 as WN4UUQ, Novice class. Back then a Novice class license was good for 12 or 24 months, I forgot. Instead of learning code I had a Heathkit 2er (2 meter five watt AM transceiver) and just chatted locally. Back into the hobby about 1977 as WN5THT then WB5THT. I've been an Extra class (with 20 WPM code) since about 1994.
Currently active on JT65 using an Elecraft K3s. Since my first "real" transceiver after moving past Novice class was a Kenwood TS-520, I also have one in my station as well as a Kenwood TS-830. For 75 meter nets I use an Acom 1000 amplifier (1000 watts output.)
73 de John WB5THT
Offline tkuhmone
« Reply #65 on: February 09, 2017, 11:44:45 pm »
hi,
OH7HMS here, from southern Finland. Can also use OF-prefix at call in 2017, as 100th independence year at Finland :-)
Got my license at 1998 when was on the end phase of my telecomm engineering studies. Currently setting up a remote station to central Finland. There is less radio pollution on the air and more places to put antennas for HF bands. I have tested there FT-817ND, but more powerful rig is on the list. I think 50...100W will be sufficient next step on power output. It could be SDR radio, maybe from Flexradio...
Until couple of years ago I mainly used equipment (radios, antennas and test equipment, see link) on the local hamradio club. Currently belong to a new club, there is still possiblity to have contacts and some tweaking & RF measurements with electronics :-)
http://tinyurl.com/jndeanh
Timo, OH7HMS
Offline Luap2
« Reply #66 on: February 20, 2017, 04:43:42 pm »
WL7XQ  Anchorage,Alaska
« Last Edit: February 20, 2017, 04:52:11 pm by Luap2 »
Offline kgharibyan
« Reply #67 on: February 20, 2017, 04:48:15 pm »
EK7PP
Armenia
73 !
Sent from my iPhone using Tapatalk
Offline jopie
« Reply #68 on: February 23, 2017, 09:04:52 am »
PG4I from the Netherlands, since 1976 (former callsigns PA3ABA and PA4TU). Mostly CW and contesting below 30 MHz. And homebuilding of course...
Offline cprobertson1
  • Country: scotland
  • 2M0XTS / MM6XKC
« Reply #69 on: February 24, 2017, 01:28:48 pm »
MM6XKC from Irvine, Scotland: active since November 2016 - will hopefully have an intermediate license in a month or two!
Primarily VHF-FM with occasional VHF-USB, UHF-FM and UHF-USB: will be live on from March 2017 onwards
Main Rig: Yaesu FT-991
Main antenna: Diamond X-50N Collinear (2m/70cm)
Secondary antenna: G5RV 1/2 size
Tuner: MFJ-939Y
Portable Rig: Baofeng UV-5R
Main antenna: 38cm whip
Secondary antenna: backpack mounted 90cm loaded whip for QRP work
Tertiary Antenna: 10cm Rubber Ducky or 3cm Stub antenna
Offline W2NAP
« Reply #70 on: February 25, 2017, 01:00:18 am »
not on radio much, if I do any HF it is 99.9999999999% jt65/9
Offline W9GFO
« Reply #71 on: March 13, 2017, 02:58:20 am »
                     `. ___
                    __,' __`.                _..----....____
        __...--.'``;.   ,.   ;``--..__     .'    ,-._    _.-'
  _..-''-------'   `'   `'   `'     O ``-''._   (,;') _,'
,'________________                          \`-._`-','
 `._              ```````````------...___   '-.._'-:
    ```--.._      ,.                     ````--...__\-.
            `.--. `-`                       ____    |  |`
                `._`.        __________   `.      \'__/`
                   `-:._____/______/___/____`.     \  `
                               |       `._    `.    \
                               `._________`-.   `.   `.___
                                             SSt  `------'`
At first I was just going to post a couple arrows pointing to the left, 'cause that's where you'll see my call sign, then I spotted this "move" button, then tried it with ASCII art... too much?
Offline janoc
« Reply #72 on: March 13, 2017, 09:11:45 am »
 :clap: :-+
Offline Richard Crowley
  • KJ7YLK
« Reply #73 on: March 13, 2017, 01:02:59 pm »
The last guy who posted a large piece of ASCII art in these forums has been arrested and locked up for anti-social behavior. But perhaps that is just a coincidence.   ;)
Offline retroleftyTopic starter
« Reply #74 on: March 13, 2017, 04:35:37 pm »
                     `. ___
            `.--. `-`                       ____    |  |`
                               |       `._    `.    \
                                             SSt  `------'`
 Never seen that before posted here, kind of unique. We Hams have a history of using what they have to get the most out of what they do have and know.  :-+
