So let's say you measure a signal's power with a spectrum analyzer and the 20Mhz fundamental is -10.8dbm followed by harmonics of -52.7dbm, -70.2dbm and -75.3dbm, -67.6dbm and -71.9dbm. What would and should a broadband power meter read? The sumation of the fundamental with the harmonics? I don't have an accurate power meter, have been thinking of building one using one of the AD chips and an STM32F4 and display but was wondering how you would calibrate it?
The same question applies to my signal generator, an HP 8648C, which I assume generates a fundamental at the power level selected. I was thinking about calibrating the power meter using a table of power levels and frequencies but then I thought about this issue. But I guess it also comes down to what you want to measure. I would generally be measuring the fundamental with a power meter so using the signal generator would get me close enough, or would it? It would also depend on sine vs square vs triangle, no?
I was also wondering about people I know that have used power meters to determine the insertion loss of a low pass filter. Since the filter has more impact on the harmonics, wouldn't the insertion loss really not be anywhere near correct (on a low pass filter)? In my example above, if a broadband meter is reporting the sum of the fundamental with harmonics within its range, it would report a higher insertion loss on a low pass filter than actual because the harmonics are now attenuated, no?
Opinions? (ha, sort of dumb asking this group for opinions as I will get them without the question
Thanks
