Hi!
I'm in need of something for my next project and I'm looking for some help, given that I lack the needed experience.
What I'd like to do is transmit an ON/OFF signal (just a single bit of data) to 1-2m distance at most, in a single direction (only one party sending). There is no need for any security whatsoever, this is a completely non-critical application security-wise.
While it might be relatively easy to hack together something like this at home, I need this for a future product. As this would constitute an "intentional radio emitter", certifications down the road (FCC, RED, etc.) would be much too cost-prohibitive and unfeasible (I guess/think?) for a home-brew solution. I was hoping somebody here knows a pre-certified module, such as those available for BT or WiFi where certifications later on are greatly simplified, only, you know, simpler. Something like a dumbed-down wireless garage opener (with shorter distance and no security).
One option is of course to take a pre-certified module for a more complicated "technology", such as a bluetooth, and use that, but that is totally over-engineered for my needs. Well, it could be plan B (if everything else fails) actually, but I was hoping there is a module that is closer to my "barbaric application", as that is potentially both cheaper and smaller (I need size to be small).
Or maybe somebody knows a 3rd solution that could fit me?
Thanks for your help.
