A ham friend asked me to look at this rig. It has no output power on any of it's bands. After some research I found the following known issue -
the high IC ALC problem which resulted in no TX output power in the
radio. A few of use sent our radios to the same place here in the USA...
and this place replaced the same 6 smd resistors to fix the radio.
The 6 smd resistors that were replaced were...
R3034 & R3035 - 5.6K ohm
R3038, R3040, R3041, & R3042 - 6.8K ohm
All 6 of these are located on the bottom of the PA Unit.
https://beta.groups.yahoo.com/neo/groups/FT100/conversations/topics/36891
As you can see in the attachments, we see the true output power is about 0 dBm - there is a 40 dB attenuator inline to protect my spectrum analyzer in case it decides to work. The output power at this time should be +50 (100W). Frequency is off too.
Also, we can see the ALC indication is hard full scale, which is consistent with the known issue described in the research. So, we will see if I can repair it, I have no idea if it really has the same issue or not, but it looks promising. Will have to pull the PA board out next because the SMD resistors are on the bottom.
Oh, by the way, how about that microphone!
