Even inexpensive 10x probes are going to be very high impedance and very low capacitance in those bands and should be just fine for looking at your signal.
Just terminate the like properly, then probe the signal pin, ideally using a spring ground clip to minimize parasitic inductance, but at these frequencies even the flying ground lead isn't too bad.
