Hello all,
I'm developing some products in ISM band (868 MHz). The part of the development is also testing the products (reception parameters, transmission parameters). Currently they are done using a classical spectrum analyzer (for Tx parameters). Reception parameters are done with our custom tools.
But I want to throw our custom tools out of the system.
Therefore I would need a RF generator.
Typically I'm measuring:
- reception bandwidth (changing frequency with fixed amplitude)
- sensitivity level (estimation)
- packet handling (transmitting different test packets)
- burst testing (transmitting large amount of data - multiple telegrams transmitted successively)
I have few hard requirements - it must be programmable (via USB/LAN), and amplitude must be stable.
I'm quite sure, that SDR is a way to go, but I'm worried about amplitude stability.
I can not find any (good?) information about SDR (Ettus USRP for example) amplitude stability.
I do not need
extreme amplitude stability - for my cases it is enough that amplitude does not change for more than +/- 0.5 dBm. Actual amplitude value is not as much important to me, as stability over time.
How do SDRs preform? Any experience? Which device would you suggest?
Or do you think using a "real" RF generator (something from big players) is a better way to go?
Currently I'm looking at LimeSDR mini, and it seems to have everything I would like to have. But - I can not find any data about amplitude stability.
What do you think? What are your experiences?
