Hello everyone,
I'm quite a newbie regarding RF designs. I've recently started to experiment with RFM69HW-433 modules to put them together with my Atmega based sensors. In order to have compact design, I've started to experimeth with Linx Technologies sourface mount antennas
https://www.linxtechnologies.com/wp/wp-content/uploads/ant-433-sp.pdfI've prepared following adapter
, in order to experiment with radios using prototype boards.
The problem is my radios are getting killed. After a short time, there radios staring to have short circuit. It was not happening whem I was using antenna of 1/4 wavelength done from piece of wire.
Should I have some matching circuit for antenna ? Is there any way to tune it without spectrum analyzer ?
Could you be so kind to give me any clue / materials to read so I could fix this issue ?
Regards,
Piotr
