OK here it is before soldering....
Very likely one of the wrapped connections isn't making good connection.
Also, long wire lengths are a bad idea at 433 MHz.
Three 10pf in parallel for the 3.3pf
Did you make the same mistake you made last time? Three 10pf in parallel is 30pf. Three 10pf in series is 3.3pf.
Where it says "data in" those leads are just open. Should they be shorted? Connected to high value resistor? A low value resistor?
The lead with the resistor should go to 5 volts. You can connect it to ground, then a 27 K resistor from the base of the transistor to the 12 volt rail. That will put about 5 volts on the base of the transistor.
I think you should go to the Talking Electronics pages mentioned in a previous post and look at the FM "Bug" transmitters. They'll be a lot easier to get working and you can test them with any transistor radio.
Yes the caps are in SERIES now, heh. So I made this again with a brand new trans just incase with no wire wrap all leads are wrapped around each other, was almost easier then wire wrap. I upped the coil to 25 turns, because the HAM radio inductor calculator said that was :0.0029718030670158003uH, which is 29.7nH? Or is it 2.9nH and I need to increase the coil by a factor of ten, which is not ten times as big (I still haven't made enough inductors to figure out what the relationship in size/turns is to value, When I think that its double its usually not even close) but the physical size just seems to be way bigger then any picture I have seen of any other circuit.
So to give the DATA line signal : I add a 27k resistor, connecting one end to data in resistor and the other to +12 volts? What do I connect to the other data in to, just ground or do I leave it open?
This new version also pulls 0.000A, first time I turned it on it went to 0.003A for less then a second, then down to 0.000A I have set the current limit to 0.005A then tried it at 0.015A it still wont light the LED that was coming on with the wire wrap circuit. So I don't think that the transistor blew up. I have read a lot on the site I got this from but this circuit has no explanation. Maybe it IS just an "idea".
Thanks for all the help!
Can you download this spice program for free?
